welcome @forums.autodesk.com!
>> the drawing have on it, hatches with diferent colors
Can you please select any of these hatches while the property window is active (<CTRL><1>), make a screenshot and upload the screenshot here (so we can see the entities properties.
What you can try too:
Start command _MAPWSPACE to get the Map 3D task pane, on "Display Manager" see if there are styles defined that override the entities colors.
![2014-06-14 23-15-45.png 2014-06-14 23-15-45.png](https://forums.autodesk.com/t5/image/serverpage/image-id/106222iE88FB8007980FAC3/image-size/original?v=mpbl-1&px=-1)
![2014-06-14 23-16-04.png 2014-06-14 23-16-04.png](https://forums.autodesk.com/t5/image/serverpage/image-id/106224iB08935A4E1650BC5/image-size/original?v=mpbl-1&px=-1)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2024------------------------------------------------------------------------------------
(not an Autodesk consultant)
