welcome @forums.autodesk.com!
>> the drawing have on it, hatches with diferent colors
Can you please select any of these hatches while the property window is active (<CTRL><1>), make a screenshot and upload the screenshot here (so we can see the entities properties.
What you can try too:
Start command _MAPWSPACE to get the Map 3D task pane, on "Display Manager" see if there are styles defined that override the entities colors.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2024------------------------------------------------------------------------------------
(not an Autodesk consultant)
