AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Drawing turns into white
1 REPLY 1
314 Views, 1 Reply
Hi!
Im using Autocad Map 3D 2014, and i'm drawing a map showing land use, the drawing have on it, hatches with diferent colors. The problem is, when i open the project all the drawing turns into white color, but the information layer still showing the colors i have determineted for each hatch and line.
HELP. How Can i Solve this.
1 REPLY 1
Alfred.NESWADBA
welcome @forums.autodesk.com!
Can you please select any of these hatches while the property window is active (<CTRL><1>), make a screenshot and upload the screenshot here (so we can see the entities properties.
What you can try too:
Start command _MAPWSPACE to get the Map 3D task pane, on "Display Manager" see if there are styles defined that override the entities colors.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Technology Administrators
AutoCAD Beta
