If your goal is to simply put your points into Google Earth Pro, then you do not need to create ‘calculation columns’ in the SDF table. Map3D is fully capable of exporting your SDF formatted points into another format GE Pro understands. The newly exported file can then be opened using GE Pro (actually ‘imported’ by GE Pro) and your points will appear accurately on the Google map.
<<The user, that’s you, doesn’t have to calculate and view those two extra columns in the SDF’s table in order for export to occur. All mathematical calculations occur behind the scenes.>>
The key to all this is to make sure your SDF points are geospatially accurate. First, open a brand new, clean metric template and assign an appropriate projected coordinate system. Next , bring in your SDF points using a Data Connection then turn on Bing Hybrid Maps so aerial imagery appears as a basemap. If the points look correctly positioned against the aerial photo background, you’re good.
<<If the points don’t appear geospatially accurate, then something’s wrong and you’ll need to investigate and take corrective action, up to and including, a total re-do of the points.>>
If your SDF points are geospatially accurate, turn off (uncheck) the point layer in the Map Task Pane. Next, use MAPIMPORT command and import your SDF points into this new drawing. The Mapimport command will convert the points from SDF entities into AutoCad point entities. At this point you'll have the points sitting in modelspace in two different fomats: (A) AutoCad point objects and (B) SDF feature data objects (although the SDF entities are not currently visible b/c you have turned them OFF in the Map Task Pane).
<<If your imported points are not easily seen, use PTYPE command and change the point style. You may change from the default '.' dot style to another, e.g. the style that looks like a circle with an X.>>
Next you will use MAPEXPORT command to export the AutoCAD points to shapefile. If your soon-to-be exported points are sitting in drawing currently referenced to OSGB British National Grid Meters, then the MAPEXPORT command will also allow you transform the SDF’s georeference from OSGB to WGS84 Lat/Long or the coordinate system used and understood by GE Pro.
<<By default, the MapExport command, will adopt the current drawings's coordinate system and use it to create the shapefile's prj file. Howver, you have the option to not adopt the current drawings CS and use a an alternate CS selected by you. This is conversion, from one CS to another, is performed on the 3rd Tab of the MapExport procedure. Simply select WGS84 (aka LL84) using the Coordinate System Library button, it looks like a globe, then check the box named Convert coordinates to. Don't forget, you'll still need to complete the 1st and 2nd tabs of the MapExport command.>>
Finally, from GE Pro go to File=>Import=>change files of type to '.shp'=Browse to and select your newly created shapefile=>Open.
Optional: Once the shapefile is mported perform a SAVE AS and save the point file as a kmz or kml. If you wish, you may email the kmz/kml to a colleague in another office. In the end you’ll not only have your points in its original SDF format but you’ll also them in shapefile and kmz/kml too. Those extra columns you originally wanted to add, can be, and should be, totally avoided.
Chicagolooper
