So to be clear, you survey trees and during your filed work, you not only collect location (lat/longs), you input the tree species, trunk diameter and possibly even the estimated height and condition. Correct? What is the format (extension type) of your data when you input it to Map3D?
Would it be possible to upload a sample of the survey data that M3D is consuming?
Chicagolooper
