Convert Object Data Field
Pointdump
Consultant Consultant
Message 1 of 14
Pointdump
Is there a way to convert the OD field from "420 ft" to just "420" so that I can use the elevations to create a surface in Civil 3D? When I Attach and Query I get a dialogue box that says "Check for possible mismatched data type in the expression." So I guess I need to remove the "ft" part and change the field from string to integer.
The original contours were in GDB files. I converted the GDB to SHP in QGIS.
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Accepted solutions (3)
Replies (13)
Message 2 of 14
АлексЮстасу
ODEDIT_REPLACE
In the ELEVATION field, replace " ft"(space and "ft") with "", i.e. empty, nothing.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 3 of 14
ChicagoLooper
Yes, of course it can be done.
  1. Open a clean, brand new drawing and assign an appropriate Coordinate Sytem. Execute MAPIMPORT on the 20ftContours_26918 shapefile and create OBJECT DATA during this import procedure. The contours will appear in model space as AutoCAD polylines.
  2. Go to Map Setup Tab=>Attribute Data Panel. Make sure '20ftContours_26918' is displayed in the Table dropdown menu.
  3. Highlight ELEVATION=>Click MODIFY
  4. Under Field Definition section, go to TYPE=>Integer=>OK (Be patient and wait for M3D to process the data change from Character to Integer.) Select a contour and verify in Properties Palette whether 'ft' has been removed.
  5. Save this drawing in your project folder giving it a name such as '20ftContour_Setup.'
  6. In another drawing, either new or existing, attach the setup dwg to Task Pane and perform a query. You can now use Alter Properties function to raise the contours to their proper elevation.
Chicagolooper
Message 4 of 14
O_Eckmann
1. Open DBF file in LibreOffice Calc 7.0.1
2. Select column ELEVATION and Ctrl+H (find and replace) " ft" by ""
3. Save your DBF (if you have a error message with LENGTH column, reduce number of digit)
4. MapImport your SHP
Olivier
Olivier Eckmann
Message 5 of 14
Pointdump
Hi Alexander,
Thank you. That will take out the " ft", but it remains a string. I need an integer or real to create a surface in Civil 3D. I used MAPEXPORT on your drawing and opened up the shapefile in QGIS:
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 14
Pointdump
@ChicagoLooper,
"2. Go to Map Setup Tab=>Attribute Data Panel. Make sure '20ftContours_26918' is displayed in the Table dropdown menu."
You lost me here. What am I looking for?
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 14
Pointdump
Hi Olivier,
I think you can open a DBF in Excel as well. And I also have DBF Commander. But the big problem is that I need to also convert the string to an integer or real to create a surface in Civil 3D.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 14
Pointdump
@ChicagoLooper,
OK, so what I needed to find was "Define Object Data". And that did work indeed, even stripping out the alpha characters. Now I'll see if I can create a surface in Civil 3D with the modified OD.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 14
ChicagoLooper
Works for me.
BTW,
when you change the Object Data from 'Character' to 'Integer' you are changing the OD from string to numeric. You are not changing the dbf file. So if you open that same shapefile in QGIS then you are still reading the same ol' dbf so it'll still be a string. After you've changed the data type from character to integer, save and attach this saved dwg to another drawing. You can query and simultaneously perform alter properties to create raised contours. The properly raised contours will be your surface definition.
You don't need to take the original shapefile back to QGIS, that's an unnecessary step. Simply raise your contours using Alter Propeties so you'll have your surface definition.
Chicagolooper
Message 10 of 14
O_Eckmann
Hi Dave,
With DBF Commander, in File Menu, you have "Structure" command (or Ctrl+S)
And you can change the type from character to integer or double.
With Excel you can open DBF file, but you can't save to DBF (it's stupid !), that's why I prefer to use LibreOffice.
And in LibreOffice, 1st line contains type of data. Cell D1 (for ELEVATION field) contains "ELEVATION,C,7" with means Character with 7 letters. You can replace it by "ELEVATION,N,5,0" to convert to integer or "ELEVATION,N,10,2" to convert to double with 2 digits for example.
Olivier
Olivier Eckmann
Message 11 of 14
O_Eckmann
Hi Dave,
In QGIS you could add a new integer field and filled it with ELEVATION field via some action
And your SHP/DBF is OK to create a Surface from GIS Data in Civil 3D without using CAD Polyline with elevation.
Olivier
Olivier Eckmann
Message 12 of 14
Pointdump
@ChicagoLooper,
I greatly appreciate your help on this one. This rabbit hole was actually a side trip. I needed a County-wide Surface to test a Custom Low-Distortion Projection.
"You don't need to take the original shapefile back to QGIS..."
I did a MAPEXPORT and dropped it into QGIS just to quickly see if it "took". I haven't created a Surface yet in Civil 3D because I need to verify the elevations. Original data was, I think, in UTM83-18, which is a Metric CS. Which makes me question the " ft" part.
<Rant on>
When data, any kind of data, is posted with incomplete, faulty, or non-existent metadata, my temples throb with anger. And don't get me started about data in proprietary formats.
<Rant off>
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 14
Pointdump
Olivier,
Thank you for that. I knew there had to be a way in DBF Commander. (Not a program I use much.) And I will keep LibreOffice in mind. I used it once to open and save a spreadsheet that Excel wouldn't open.
There's also a way in QGIS to convert a string to integer or double, but with Map it's easier, and I like to exhaust all possibilities in Autodesk software first before turning to other software.
Thank you again.
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 14
Pointdump
Olivier,
Thanks for the QGIS way, and I keep forgetting "Create Surface from GIS Data" in Civil 3D.
Dave
Dave Stoll
Las Vegas, Nevada
