How can I set X, Y coordinates with a tablet.
Hi I'm digitizing a map with my tablet, and set the new coordinates (0,0) (100, 100).
I want to digitize in the range (0~100) along the axis.
Is it possible?
I success to connect the tablet with Autocad, but I can't set the coordinates in the Autocad screen.
I tried to use command "TABLET" CFG and CAL, but these cannot help me to set the new coordinates.
АлексЮстасу
If I got it right...
1. Draw a horizontal line with coordinates 0,0 and 0,100.
2. _ALIGN the image to rotate and scale to that line.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
O_Eckmann
For using your tablet as a digitizer, you need to obtain wintab driver v1.1. Without these driver your tablet is only recognized as a mouse.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Obtain...
Olivier
Olivier Eckmann
