Connecting a *.gdb file
Muthya
Message 1 of 35
Muthya
I am trying to connect to the attached *.gdb file in my hard disk. Having difficulties. Opens in other GIS application (QGIS).
Is there anything I can do to get this to Map 3D for further work?
Accepted solutions (4)
Replies (34)
Message 2 of 35
parkr4st
what version of Map3d are you using?  2019, 2020?
Message 3 of 35
Pointdump
Seshagiri,
I've heard you can use MAPIMPORT to bring a GDB file into Map 3D, but I've never been able to. I tried just now in 2020 version--no luck.
What I do is open in QGIS, then save as a SHP, which you can easily import into Map.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 4 of 35
parkr4st
I did connect with Map3D 2020 with no problem.
Add ArcGIS connection
file /personal GDB  tab
FGDb button and select your .gdb folder
Connect
Select DS_Stormwater
add to map
Message 5 of 35
Muthya
Could you please send me some screen shots of the process. I am not getting it.!!!
Thanks.
Message 6 of 35
Muthya
I am using Civil 3D V-2021. Map 3D is embedded as "Planning and Analysis" workspace.
Thanks and Regards.
Message 7 of 35
Pointdump
Dave,
I tried your steps in 2020 just now and I get "Failed to Connect".
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 35
parkr4st
go back one folder and try
Message 9 of 35
Pointdump
Dave,
I tried back one first. Nope. There must be some key thing I'm missing.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 35
O_Eckmann
On my Civil 2021, connect button does nothing.
I think that ESRI licensed product (ArcGIS) is necessary to connect to ArcGIS data even to FGDB
@parkr4st do you have ArcGIS product installed on your PC?
Olivier
Olivier Eckmann
Message 11 of 35
Muthya
ArcGIS licence is required only for Enterprise or ArcGIS online. FGDB, PGDB files that reside on your hard disk do not need an ArcGIS licence. Because, if you had an ArcGIS licence why bother with Map 3D? You can as well work directly on ArcGIS !!!!
Wonder why some one from AutoDESK is not addressing this issue.
Message 12 of 35
parkr4st
Yes.   That may be it.
dave
Message 13 of 35
O_Eckmann
Hi @Muthya ,
If I've well read information from Autodesk, FDO ArGis provider is the same to connect to ArcGIS and FGDB and this provider needs ESRI license : https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles...
Olivier
Olivier Eckmann
Message 14 of 35
Muthya
If I have ArcGIS license, why do I need Map 3D at all !!!!
Message 15 of 35
ChicagoLooper
If you're running ArcGIS, then you can do this?
  1. From Data Connect Palette=>Add ArcGIS Connection=>FGDb button
  2. Drill down to your geodatabase FOLDER=>OK=>Connect
  3. Select your layers=>Add to Map
1-From Data Connect Palette, select FGDb1-From Data Connect Palette, select FGDb
2-Browse to your FOLDER that contains your GDB.2-Browse to your FOLDER that contains your GDB.
3-Check your layers=>Add to MAP3-Check your layers=>Add to MAP
If you don't have ArcGIS then you can ask a colleague to open the gdb in Arc Desktop or ArcGIS Pro (or QGIS) and pull the Feature Class out of the gdb. The feature class can be saved as a shapefile. You can then connect to (or mapimport) the shapefile in Civil3D/Map3D
Chicagolooper
Message 16 of 35
ChicagoLooper
Hello @Pointdump
I'm looking at your uploaded images, specifically Browse for Folder image..........try drilling down one more folder. Then OK=>Connect.
Chicagolooper
Message 17 of 35
Pointdump
@ChicagoLooper,
"...try drilling down one more folder."
Tried that. Nope.
I think it's as Olivier says, gotta have an ESRI license.
Dave
Dave Stoll
Las Vegas, Nevada
Message 18 of 35
ChicagoLooper
@Pointdump
OK, I see. Then you'll need to use 3rd party software, e.g. QGIS, Arc Desktop or ArcGIS Pro, etc. to read the gdb then pull the Feature Class out and save it as a shapefile. The gdb connected using M3D's Data Connection is shown below with Bing Hybrid.
Connected to FGDb. Site is on 33 Street in UAE.Connected to FGDb. Site is on 33 Street in UAE.
Chicagolooper
Message 19 of 35
Muthya
This is not working.
There are suggestions that you should have a license for ArcGIS in order to connect to an FGDB file residing in a local hard disk. This defies logic as, if I have ArcGIS, why should I use Map 3D?
Message 20 of 35
Same issue here.  I've got civil 3D 2020, and ArcGIS Pro installed.  when I click "connect" nothing happens.  no warnings, no nothing.  The .GDB opens just fine in ArcGIS Pro.  We are working on creating  way to keep all our survey boundaries in one large database, but need to make this easy for the surveyors.  Isn't the whole point of Map3D to be a link between esri and autodesk?
