I use both the Title Software. I feel at ease to use online Satellite Image as backdrop in ArcGIS Desktop but feel deprived when facility is not found in AutoCAD Map 3D Environment. Is there any solution to it?
Basemaps for Map3D are available. Options include:
Bing Maps: Map Aerial, Map Road, and Map Hybrid.
Th ribbon for ArcGIS for AutoCAD once the plugin is installed. The table of contents is the panel on the left.
Thank you very much for guidance.
Image backdrop appeared at AutoCAD Map 3d 2020 Model Space.
But when i overlayed GIS data digitized from Google Earth, it showed a noteable shift beyond ignorable limits. Why it is so?
Another issue faced has been the quality of image. The image when zoomed in, to approx. 1:500 scale, it gets confusingly blur.
Please explain what when i overlayed GIS data digitized from Google Earth, it showed a noteable shift beyond ignorable limits means.
Please describe your GIS data. Is it shapefile, geodatabase, raster, or something else.
What basemap in the background is off? Is Bing Hybrid off? Or some other basemap such as a map you connect to when using ArcGIS for AutoCAD, e.g. the Living Atlas?
When you say GIS digitized from Google Earth, are you referring to a kmz/kml file? Are saying your kmz/kml file doesn’t align with your basemap background?
What coordinate system is assigned to modelspace?
Would it be possible to post screenshots of your dawing where the GIS data has shifted? Or you may upload your drawing for troubleshooting.
