Message 1 of 14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a way to convert the OD field from "420 ft" to just "420" so that I can use the elevations to create a surface in Civil 3D? When I Attach and Query I get a dialogue box that says "Check for possible mismatched data type in the expression." So I guess I need to remove the "ft" part and change the field from string to integer.
The original contours were in GDB files. I converted the GDB to SHP in QGIS.
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
