Did you use the FdoUsersManager.exe to create the role? Located in the
FDO/Bin folder for Map3D/C3D...
You may want to look over these threads.
http://discussion.autodesk.com/forums/search.jspa?threadID=&q=Oracle+XE&objID=f85&dateRange=all&numResults=15
#7 and #4 might be of some help with the xe version of Oracle. All I used
was the full 10 G versions, that worked right out of the box.
Also there should be some document in the install/setup folders on the DVD.
It's been a while since I played with Oracle.
Murph
http://map3d.wordpress.com/
"scohen" wrote in message news:6302750@discussion.autodesk.com...
Murph,
First, thanks a bunch for getting back to me (I love your blog too :-). Ok,
so I am NOT an Oracle/SQL kinda guy, however, I am fairly technically savvy
:-). So, I added the user F_USER_ROLE, but how do I add the SQL file, or do
whatever else I need to do to get this to work? Also, do I eventually have
to use the F_USER_ROLE as a service AND a user login when connecting?
Thanks again Murph, I really appreciate it.
-Seth Cohen
