AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
JPG file how to insert in proper co-ordinate
6 REPLIES 6
411 Views, 6 Replies
I have jpg Google image ...
how to insert that file in proper co-ordinate in CAD..
If some one knows the procedure how to fix that image in proper place in CAD...
6 REPLIES 6
A jpg image you got with a Google search? or from Google Earth? Using
AutoCAD Map3D or plain AutoCAD CAD or Computer Aided Dispath.
Version of "CAD" and method of getting the image may help answer the
question.
Murph
http://map3d.wordpress.com/
"umeshsurya1" wrote in message news:6292903@discussion.autodesk.com...
CAD...
I am using AutoCAD MAP 2008 and 2009.
And the image is from ? Is it in a known coordinate system? Is there
metadata for it on the site you got it from?
Murph
"umeshsurya1" wrote in message news:6293212@discussion.autodesk.com...
I have no idea about jpg file.....
it look simple jpg file.....
if possible could u please explain more...
thanks
WHERE DID YOU GET THE JPG FILE?
If you did a Google search and found a jpg you wanted then downloaded/saved
it to your computer then it is not georeferanced. You will need to insert
the jpg with the mapiinsert command and use the scale, move and align
commands in AutoCAD to place it where it needs to go or use the transform or
rubbersheet commands in AutoCAD Map3D. You will need to have known points in
the dwg and on the jpg.
Murph
"umeshsurya1" wrote in message news:6293420@discussion.autodesk.com...
thanks
I have Georeferenced image that are jpg with a jfw meta file how do i get map from Map>image>insert to see the correlation file?
Technology Administrators
AutoCAD Beta
