We've recently updated to 2015 with the whole suite of Autodesk (Civil 3D, Map, etc) and have ArcMap 10.2.2 and are unable to connect via Arc SDE. I copied the typical DLL files to the appropriate fdo/bin folder and made sure it is pathed in the options in both Map and Civil 3D. I even tried copying other DLLs like suggested in other posts. However, when making the connection, it appears the connection is made (no error when we enter user id and password), but the pull down menu doesn't populate with data to add to CAD. (Although there is not a connection listed in the Data Connections list.) Trying to determine where the problem is. Anyone have any ideas? We've tried this on a couple of computers in our office and seem to get the same result. Any help would be appreciated!! I've reached out to AutoDesk through our subscription service and while they say 10.1 is supported versions of 10.2 so far are not, so I'm trying to seek help here.
Hi
C:\Program Files\Autodesk\AutoCAD 2017\Map\bin\FDO, if you have a Suite or collection, map and Civil3D share the same libraries and it should work
If you have separate installs it will need to be in both.
Please note that 3 files will not help. you need all the below dll's
gsrvrmssql102.dll
gsrvrsql102.dll
icudt44.dll
icuuc44.dll
pe.dll
sde.dll
sdemssqlsrvr102.dll
sg.dll
xerces-c_3_1.dll
Hi jnel,
I am also trying to connected AutoCAD map 3d 2018(64 bit) to work with ArcSDE 10.2.1(32 bit) on SQL Server 2008 R2, Standard using the ArcSDE provider.
I have copied all the required dlls (64 bit, as per your comment) in the Map/Bin/FDO directory.
But I am getting the below error.
"No SDEHOME environment variable set (-95)
Failed to open ArcSDE connection. "
any idea about this?
I have not done any entry in C:\Windows\system32\drivers\etc\services file. is it necessary to make a entry in this file? If yes, can you please help me with the format for 10.2.1?
one more thing, ArcGIS client is not installed on my machine on which I am running the AutoCAD.
Any suggestion will be a great help.
Thanks in Advance.
Hi @Anonymous
Best article to follow
Your problem is that your SDE is 32 bit (really in 2021 😊 ) and Autodesk no longer make 32 bit software. You need to get 64 bit sde dll’s
