AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export hatches to polygons?
7 REPLIES 7
Message 1 of 8
13011 Views, 7 Replies
Hi all,
Is there anyway to export hatches to polygons?
7 REPLIES 7
Message 2 of 8
Forgot to mention:
I tried to recreate boundaries with hatchb.lsp script, and then create topology with those boundaries. But then, all "holes" in hatches are treated as new polygons. What I need is just a simple procedure to export existing hatches to .shp or anything else, just as they are, with holes and everything.
Message 3 of 8
If your hatches have inner and outer boundaries as polylines then convert them together using the mpolygon command before export. The shp file will retain the geometry or islands.
John
Message 4 of 8
Thanks for reply, JohnPM.
I have two cases.
In one, hatches have boundaries, but they are in different layer. Does this matter? If yes, I will move them to same layer.
In other case, unfortunately I have no boundaries. I found this to recreate boundaries:
http://www.jtbworld.com/lisp/hatchb.htm
But, after exporting result of this script, I have problems with islands, as mentioned before.
Is there any "proper" way to recreate inner and outer boundaries from ONLY hatches?
Message 5 of 8
I have always used hatchedit for recreating boundaries with a polyline and if you are manually selecting the boundaries to create an mpolygon it should not make a difference which layer they are on. Map 2010.
John
Message 6 of 8
Well, that is ok to recreate boundaries from few hatches. But what if you have few thousand hatches? Hatchedit doesn't allow "select all" or I am doing something wrong.
Message 7 of 8
i have the same problem...
how do i get boundaries back of several hatches at a time...?
Can anybody help ,Please..?
Message 8 of 8
ahsattarian3
Use these commands  :
hatchgenerateboundary   &   generateboundary
