Can Autocad insert, link or connect a COG image, (Cloud Optimized GeoTIFF)?
Valentin_CAD
Mentor Mentor
Valentin_CAD
Can Autocad Map insert, link or connect a COG image, (Cloud Optimized GeoTIFF)?  (Sample)
I know adding an Geo Reference Tiff is usually done with the MAPIINSERT Command or FOD.
Has anyone done this with a COG image? - If so, explain the process.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Valentin_CAD
Please contact Autodesk Custom Support or wait for them to implement this new feature in future releases.
https://www.autodesk.es/support/contact-support
Emilio Valentin
TerryDotson
No matter how tight the grid interval is, a TIF is a raster which is a derivative of what likely started out as Lidar.  As a raster it loses fine details like ditches, walls, etc.  It would seem to me that small granular tiles of classified Lidar in LAZ format (better compression) would be not only easier to stream, but also lead to better end results (TinSurface).
Valentin_CAD
Resource Information:
Related: LINK
Emilio Valentin
