Can Autocad insert, link or connect a COG image, (Cloud Optimized GeoTIFF)?
Valentin_CAD
Mentor Mentor
Valentin_CAD
Can Autocad Map insert, link or connect a COG image, (Cloud Optimized GeoTIFF)?  (Sample)
I know adding an Geo Reference Tiff is usually done with the MAPIINSERT Command or FOD.
Has anyone done this with a COG image? - If so, explain the process.
Also posted here.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Michiel.Valcke
I think you'll have more chance of finding someone with COG experience in the MAP3D forums
Personally I haven't had any experience with COG's yet, but since the format is not in the list, I don't think you can already connect it. You can always try to make a Raster Image connection and see what happens.
Post an idea, or contact Autodesk custom support to ask them to implement the feature in future releases.
jchemla
Observer
Observer
COGs are actually tiled + pyramid'ed geotiff raster files, this is a really needed feature for users to be able to load massive geotiffs at native resolution, all while interacting with them smoothly - qgis COG support for example is a great example of manipulation of COGs without the need for a tiling server like WMS.
Valentin_CAD
Resource Information:
Emilio Valentin
