I recently found a command that will bind all the xrefs into a drawing in one go.
I have unfortunately forgotten the command I used and cannot recognise it in the command list.
The file ends up with a file with the prefix 'ACAD-' and all the xrefs are bound.
Solved by Alfred.NESWADBA. Go to Solution.
do you mean command -EXPORTTOAUTOCAD ==> option _BIND?
- alfred -
you are welcome!
>> I will make a note of it now
No need to make your own note, now you know you can find it here (just searching) 😉
- alfred -
