AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
binding xrefs for archiving
3 REPLIES 3
robg2
441 Views, 3 Replies
I recently found a command that will bind all the xrefs into a drawing in one go.
I have unfortunately forgotten the command I used and cannot recognise it in the command list.
The file ends up with a file with the prefix 'ACAD-' and all the xrefs are bound.
3 REPLIES 3
Alfred.NESWADBA
in reply to: robg2
do you mean command -EXPORTTOAUTOCAD ==> option _BIND?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
robg2
in reply to: Alfred.NESWADBA
That is the one
Thanks Alfred - I will make a note of it now.
Rob
Alfred.NESWADBA
in reply to: robg2
you are welcome!
No need to make your own note, now you know you can find it here (just searching) 😉
- alfred -
Alfred NESWADBA
Technology Administrators
