The exemple I am working on is an electricity power line. First i created 2 SDF files ,one defined as a "line" which has "curve" as geometry, the second defined as "pylon" which has " point" as geometry ( see attached file: example). The first problem that i couldnt find a way to calculate automatically the angle between two successive sections of the line which would be a proprety of the pylon , This made me enter manually the angle in every pylon after measuring it with COGO Tools. The second problem is that i wasn't able to create a mechanical calculation which is a proprety of the pylon : Calculation= Cos(Angle)*Lenght(Section1)*length(section2) (section1 : the section before pylon , section2: the section after) , knowing that angle proprety is in "pylon" table and the length of every section is a result of length calculation of geometry proprety in "line" table (Calculation1 , see attached file: tables)
could anyone help me?
take a look at the attached sdf
all the needed data is in the table
the interior angle is in radians so you can calculate to degrees
draw cad objects on 3 layers, Lines, Pylons, & IntAngles, attach object data to the lines for conductortype and what ever else you need to pylons or interior angles and mapexport to the sdf
dave
Thank you for your reply , but I am still unable to make 2 successive sections of the line and the angle between them appear in the same line of the data table in order to create the calculation that depends on these 3 variables, do you have another solution please?
can be done I beleive
draw the power lines a cad lines
attach any object data desired
mapexport to sdf with OD and Properties ANGLE, LENGTH, z1,y1,z1, and x2,y2,z2
put the sdf into a map and join the data it to itself matching z1,y1,z1, and x2,y2,z2
The data will have all of data of adjacent lines in one table record with null data in the last record as the line will not have a z1,y1,z1 and x2,y2,z2 match
export the layer data to a new sdf.
open that sdf and add your calculation to the table dealing with radians to degrees in the process,
as for my other sdf file with the arcs, using Central angle = Arc length*360/circumference as (2*pi*radius) to get the angle in degrees, just seemed easier.
dave
