AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Autocad Map 3D 2014 64 bit Crashes when plotting
3 REPLIES 3
392 Views, 3 Replies
Good Day
I am an IT administrator for a Civil Engineering Consultants firm.
I have recently installed Autocad Map 3D 2014 64 bit with Servce Pack 1 for one of the users to test if it is a stable version.
Autocad keeps crashing when trying to plot to any printer.
There is no error message.
Please Help
Regards
Deven Phillips
3 REPLIES 3
antoniovinci
Are you sayin' it crashes even upon printing to a PDF virtual file..?
braudpat
Hello from France
Always the Same problem when printing/plotting to HP DesignJet , PDF Creator, DWG to PDF.pc3 , etc ?
Always the Same problem with and without Images/Rasters ?
Always the Same problem with and without FDO Layers ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Gary_Braun
This is very likely a printer drivers issue. We have the same problem where I work where if people plot using drivers from the wrong print server Map will fatal error every time. I would start there and see if that fixes it.
Technology Administrators
AutoCAD Beta
