AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Creating Feature Rules (Client Side)
5 REPLIES 5
TomWilgaWH
371 Views, 5 Replies
TomWilgaWH
Good Morning,
I'm hoping one of you fine folks can help me out with a task.
I'm looking to create a feature rule very similar to the "Validate Electrical Topology' rule in the Electric NA Model but I'm unfortunately not versed well enough to do this. I understand there are the sample files, but at this point, I'm hoping to get some assistance from the board here.
We are looking to create a rule that validates a field on the form, exactly like the validate electrical topology rule does for phase, circuit and voltage.
I'd really appreciate some help with this!
Tom
Thomas Wilga
Engineering Technician
GIS Coordinator
Field Inspector
Welland Hydro-Electric Systems Corp.
Good Morning,
Tom
Thomas Wilga
GIS Coordinator
Field Inspector
5 REPLIES 5
drewbb
in reply to: TomWilgaWH
drewbb
This should be straightforward.  Post your specs, Map 3D version, and I can whip something up.
Sincerely,
Drew Burgasser, P.E.
CAD Masters, Inc.
www.cadmasters.com
Sincerely,
CAD Masters, Inc.
www.cadmasters.com
drewbb
drewbb
You can also validate a field on a form using the Form Designer in Autodesk Infrastructure Administrator:
Sincerely,
CAD Masters, Inc.
www.cadmasters.com
Sincerely,
CAD Masters, Inc.
www.cadmasters.com
luisfernando7
luisfernando7
Community Visitor
Community Visitor
Muito bom, parabens
Muito bom, parabens
TomWilgaWH
in reply to: drewbb
TomWilgaWH
Hey @drewbb ,
Thanks for this! Although it's not quite what I was looking for, I definitely see some use for it in a few of our forms!
To clarify, I'm looking at how to create validation rules similar to the Phasing and Circuit rules.
IE: Line gets connected and will automatically attain the circuit, voltage, phase, etc of the device it is connected to.
In our system (Electric NA) I want to connect a line and know what switch it is fed from.
Hope that helps clarify!
Thomas Wilga
GIS Coordinator
Field Inspector
Hey @drewbb ,
Thomas Wilga
GIS Coordinator
Field Inspector
drewbb
drewbb
Hi Tom:
I believe that propagation is built into Electric NA.  When I look at the feature rules for conductors, I see:
PropogateElectricValues_AU
PropogateElectricValues_AI
When I connect a device to a conductor, the device will be assigned the same circuit, voltage, and phase as the conductor.
Sincerely,
CAD Masters, Inc.
www.cadmasters.com
Hi Tom:
Sincerely,
CAD Masters, Inc.
www.cadmasters.com
