Good Morning,
I'm hoping one of you fine folks can help me out with a task.
I'm looking to create a feature rule very similar to the "Validate Electrical Topology' rule in the Electric NA Model but I'm unfortunately not versed well enough to do this. I understand there are the sample files, but at this point, I'm hoping to get some assistance from the board here.
We are looking to create a rule that validates a field on the form, exactly like the validate electrical topology rule does for phase, circuit and voltage.
I'd really appreciate some help with this!
Tom
This should be straightforward. Post your specs, Map 3D version, and I can whip something up.
You can also validate a field on a form using the Form Designer in Autodesk Infrastructure Administrator:
