is there any IM or Map API to convert an FDO (or be more specific an IndustryModel Oracle based) features to ACAD enteties?
I'm looking for a way to convert FDO lines to ACAD plines etc.
Thanks, Rob
Solved by drewbb. Go to Solution.
Hi Rob:
See this post:
Also, for converting FDO to AutoCAD, I still use the industry model API as a middle man (even if I am not connecting directly to Topobase):
Autodesk.Map.IM.GeometryConverter.Fdo.Converter converter = new Autodesk.Map.IM.GeometryConverter.Fdo.Converter();
converter.ConvertFrom(some IGeometry object);
Maybe there's a direct route from FDO that I'm not aware of.
