Show only
Search instead for
I am using AutoCAD map 2016 and want to know whether this software can make a contour of chemical concentrations. I know it can make elevation contours, but I am not sure whether it can make concentration contours. I can replace the elevation with concentration data, but we have lots of data in different depths at each location, which may make it hard. Please let me know if AutoCAD map 2016 can do that. Thank you very much!
The concentrations will have to be shown one at a time per elevation level as separate FDO object layers (use separate GeoTiff raster connections, for example, for each elevation of interest).
