Show only
Search instead for
In some of my files the xrefs are changing colors and I dont understand why. I have tried to recreate the file by uploading again all xrefs, it works at first but then the colors changing happen again
VISRETAIN and XREFOVERIDE variables in the top file need to be set the way you want XREFs to behave: look up usage in HELP and see if your chosen settings for both is the reason your XREFs are not doing wat you expect them to do.
