AutoCAD LT Forum
XREF COLORS CHANGE WITHOUT REASONS
1 REPLY 1
alexia_gargiuloRL8B9
162 Views, 1 Reply
In some of my files the xrefs are changing colors and I dont understand why. I have tried to recreate the file by uploading again all xrefs, it works at first but then the colors changing happen again
Labels (1)
1 REPLY 1
VISRETAIN and XREFOVERIDE variables in the top file need to be set the way you want XREFs to behave: look up usage in HELP and see if your chosen settings for both is the reason your XREFs are not doing wat you expect them to do.
Technology Administrators
