Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
WANT PLOT SCALE TO SHOW UP IN LAYOUTS
8 REPLIES 8
Message 1 of 9
1058 Views, 8 Replies
I JUST GOT AUTOCAD LT 2010 AND WANT THE SCALE USED TO BE SHOWN ON THE DRAWING WHEN I PRINT FROM LAYOUT.
THE PLOT SCALE SHOWN IN THE PLOT STAMP IS 1:1.
I THOUGHT THERE WAS A WAY TO USE THE "INSERT FIELD"
I ALSO THOUGHT IT WOULD AUTOMATICALLY UPDATE IF YOU ZOOMED IN OR OUT.
THANKS,
LEO
8 REPLIES 8
Message 2 of 9
Are you looking for FIELD command?
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 9
I HAVE INSERTED THE FIELD "PLOT SCALE" TO A RANDOM SPOT ON THE LAYOUT BUT IT DOES NOT SHOW THE SCALE I HAVE SET FOR MY VEIWPORT (1:30,OR 1:50).
ANOTHER EXAMPLE WOULD BE IF I CHANGED THE PAPER SIZE AND HAD TO CHANGE THE SCALE TO MAKE IT FIT I WOULD WANT THE DRAWING TO SHOW THE TRUE SCALE THE DRAWING WAS PRINTED AT.
IN MODEL SPACE I HAVE THE SCALE THE DRAWING IS PRINTED IN THE PLOT STAMP. WHEN I PRINT FROM A LAYOUT IT SHOWS 1:1
I WORK IN CIVIL CONSTRUCTION. MANY TIMES THE DRAWING THAT I GET BUILD FROM ARE 1":50' OR 1":100' . TO GET THE WHOLE PROJECT ON A SHEET. IF MY CREW IS ONLY WORKING ON A SECTION OF THE JOB I WOULD CHANGE THE SCALE AND PRINT THE AREA THEY NEED SO IT IS EASIER TO READ.
THANKS FOR YOUR HELP.
LEO
Message 4 of 9
Charles_Shade
Fields will not update w/o a Regen.
Regards, Charles Shade
...and stop shouting, it's early...
Message 5 of 9
I DID USE THE REGEN HOWEVER IT DID NOT WORK.
LEO
Message 6 of 9
Charles_Shade
Some information I found thru Google:
http://discussion.autodesk.com/forums/message.jspa?messageID=6178346
Might offer some insite
Message 7 of 9
Maybe this is oversimplifying it, but I would just put a graphic scale in each viewport.
Message 8 of 9
THE INFO YOU FOUND ON GOOGLE WORKED.
LEO
Message 9 of 9
Charles_Shade
Good to know. Thanks for posting the follow up.
Technology Administrators
