AutoCAD LT Forum
WANT PLOT SCALE TO SHOW UP IN LAYOUTS
8 REPLIES 8
Message 1 of 9
1065 Views, 8 Replies
I JUST GOT AUTOCAD LT 2010 AND WANT THE SCALE USED TO BE SHOWN ON THE DRAWING WHEN I PRINT FROM LAYOUT.
THE PLOT SCALE SHOWN IN THE PLOT STAMP IS 1:1.
I THOUGHT THERE WAS A WAY TO USE THE "INSERT FIELD"
I ALSO THOUGHT IT WOULD AUTOMATICALLY UPDATE IF YOU ZOOMED IN OR OUT.
THANKS,
LEO
8 REPLIES 8
Message 2 of 9
Are you looking for FIELD command?
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 9
I HAVE INSERTED THE FIELD "PLOT SCALE" TO A RANDOM SPOT ON THE LAYOUT BUT IT DOES NOT SHOW THE SCALE I HAVE SET FOR MY VEIWPORT (1:30,OR 1:50).
ANOTHER EXAMPLE WOULD BE IF I CHANGED THE PAPER SIZE AND HAD TO CHANGE THE SCALE TO MAKE IT FIT I WOULD WANT THE DRAWING TO SHOW THE TRUE SCALE THE DRAWING WAS PRINTED AT.
IN MODEL SPACE I HAVE THE SCALE THE DRAWING IS PRINTED IN THE PLOT STAMP. WHEN I PRINT FROM A LAYOUT IT SHOWS 1:1
I WORK IN CIVIL CONSTRUCTION. MANY TIMES THE DRAWING THAT I GET BUILD FROM ARE 1":50' OR 1":100' . TO GET THE WHOLE PROJECT ON A SHEET. IF MY CREW IS ONLY WORKING ON A SECTION OF THE JOB I WOULD CHANGE THE SCALE AND PRINT THE AREA THEY NEED SO IT IS EASIER TO READ.
THANKS FOR YOUR HELP.
LEO
Message 4 of 9
Charles_Shade
Fields will not update w/o a Regen.
Regards, Charles Shade
...and stop shouting, it's early...
Message 5 of 9
I DID USE THE REGEN HOWEVER IT DID NOT WORK.
LEO
Message 6 of 9
Charles_Shade
Some information I found thru Google:
http://discussion.autodesk.com/forums/message.jspa?messageID=6178346
Might offer some insite
Message 7 of 9
Maybe this is oversimplifying it, but I would just put a graphic scale in each viewport.
Message 8 of 9
THE INFO YOU FOUND ON GOOGLE WORKED.
LEO
Message 9 of 9
Charles_Shade
Good to know. Thanks for posting the follow up.
Technology Administrators
