Visretain error
Visretain error
thomas
Message 1 of 31
Visretain error
thomas
I have a file with a few Xrefs. When Visretain = 1, the file freezes and crashes my entire computer. When I set Visretain = 0, the file saves quick and without any problem.
Is there a solution for this while keeping Visretain = 1? I need this setting on as I need to freeze and override Xref layers.
Thank you
Replies (30)
Message 21 of 31
john.vellek
Hi @thomas,
Did you try this as a new user on the workstation? I fear that something is being retained in your User Profile that might be causing this issue.
If you can try this it will tell us if your profile is damaged.  Since I found nothing else in our database regarding similar cases, I suggest the next step would be to wipe the machine and methodically resinstall OS,do all the updates, check all the C++ and .Net,  and then a new install of AutoCAD.
Before we go to this most drastic step, let's try the new user. You might also (just thinking out loud here) try installing a trial of 2017 and then see if your 2016 has been fixed. If so, you could then uninstall the 2017.
John Vellek
Message 22 of 31
thomas
I have tried another admin user and saving with Visretain and layer palette open works, but very very slowly - 70 seconds.
Returning to my usual profile and saving still freezes my PC.
Message 23 of 31
john.vellek
Hi @thomas,
I'm sorry to hear it hasn't improved anything. I know you say it happens on all drawings but could you indulge me and attach a typical drawing for me to look at?  Also, are you willing to try installing 2017 Trial version to see if that cleans up anything in the process?
Otherwise, I think it is time to rebuild the workstation without migrating any thing.
John Vellek
Message 24 of 31
thomas
The drawing I attached (ID-100) earlier in the thread is the one I’ve been
testing, along with other similar files with identical Xref setup.
What would be the advantage of installing the 2017 trial when I have the
full product? I had previously uninstalled 2016
Message 25 of 31
john.vellek
I'm sorry, I just remember that you installed the 2017 license.
I am looking at your file and it is filled with complex hatches. It takes about 7 seconds to save on my computer.
What operating system are you on?  I see that your graphics card is not on the recommended/certified list either. Do you have a different card that we could try just to see if AutoCAD still crashes?
John Vellek
Message 26 of 31
thomas
Windows 7. Unfortunately I don’t have another card.
It seems that the layer palette is the culprit? When saving, is the file
going through each custom modification to each XREF layer?
Message 27 of 31
john.vellek
Hi @thomas,
The only cases I found similar to yours points the finger at the graphics card. I certainly can't duplicate the error here and I can't find an exact case that matches your condition so I don't think it is Visretain.
Just a thought, the ID-100 file is one I ma looking at. I see that you bound the xref.  Some layers are referring to the Xref linetype. If you change those to a linetype (I am looking at Hidden2 ones) does the problem still exist?
I am grasping here. I really think the next option would be to beg, borrow, or steal a graphics card that is listed on the Recommended list to see if the problem persists.  I would also strongly consider rebuilding the workstation.
John Vellek
Message 28 of 31
thomas
Could the issue be with the file itself? I've never had this problem on my AutoCAD before. However, this file was originally created by me, then sent to a consultant who worked on it (they are on AutoCAD 2016 full version), and when it was returned to me it the file kept crashing my system. Other project files don't cause this issue.
There's nothing in the particular file that I can that's unique. I've attached another project file that seems to work perfectly fine.
Message 29 of 31
john.vellek
HI @thomas,,
As I first mentioned, your original file had lots of issues with it.  If the cleanup I did on it still did not fix the error, I suggest moving the drawing contents to a new file.
Let's see if that remedies things properly.
John Vellek
Message 30 of 31
john.vellek
Hi @thomas,
I would like to summarize what I think might be the solution for your issue so others in the Community might benefit.
  • You shared a file with someone outside your company
  • When the drawing came back you were seeing a variety of issues.
  • Upon inspection, the drawing needed clean up using Audit, Purge, -Purge>Regapps and ultimately an -EXPORTTOAUTOCAD
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 31 of 31
pendean
Community Legend
Community Legend
RECOVERALL command, run on your top file, found these problems:
Drawing: ID-100 Construction Plan Cellar.dwg
Path: C:\Users\dsaadallah\Desktop\ID-100 KT
Drawing recovery log:
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 100 objects audited
Pass 1 200 objects audited
Pass 1 300 objects audited
Pass 1 400 objects audited
Pass 1 500 objects audited
Pass 1 600 objects audited
Pass 1 700 objects audited
Pass 1 800 objects audited
Pass 1 900 objects audited
Pass 1 1000 objects audited
Pass 1 1100 objects audited
Pass 1 1200 objects audited
Pass 1 1300 objects audited
Pass 1 1400 objects audited
Pass 1 1500 objects audited
Pass 1 1600 objects audited
Pass 1 1700 objects audited
Pass 1 1800 objects audited
Pass 1 1900 objects audited
Pass 1 2000 objects audited
Pass 1 2100 objects audited
Pass 1 2200 objects audited
Pass 1 2300 objects audited
Pass 1 2400 objects audited
Pass 1 2500 objects audited
Pass 1 2600 objects audited
Pass 1 2700 objects audited
Pass 1 2800 objects audited
Pass 1 2900 objects audited
Pass 1 3000 objects audited
Pass 1 3100 objects audited
Pass 1 3200 objects audited
Pass 1 3300 objects audited
Pass 1 3400 objects audited
Pass 1 3500 objects audited
Pass 1 3600 objects audited
Pass 1 3700 objects audited
Pass 1 3800 objects audited
Pass 1 3900 objects audited
Pass 1 4000 objects audited
Pass 1 4100 objects audited
Pass 1 4200 objects audited
Pass 1 4300 objects audited
Pass 1 4400 objects audited
Pass 1 4500 objects audited
Pass 1 4600 objects audited
Pass 1 4700 objects audited
Pass 1 4800 objects audited
Pass 1 4900 objects audited
Pass 1 5000 objects audited
Pass 1 5100 objects audited
Pass 1 5200 objects audited
Pass 1 5300 objects audited
Pass 1 5400 objects audited
Pass 1 5500 objects audited
Pass 1 5600 objects audited
Pass 1 5700 objects audited
Pass 1 5800 objects audited
Pass 1 5900 objects audited
Pass 1 6000 objects audited
Pass 1 6100 objects audited
Pass 1 6200 objects audited
Pass 1 6300 objects audited
Pass 1 6400 objects audited
Pass 1 6500 objects audited
Pass 1 6600 objects audited
Pass 1 6700 objects audited
Pass 1 6800 objects audited
Pass 1 6900 objects audited
Pass 1 7000 objects audited
Pass 1 7100 objects audited
Pass 1 7200 objects audited
Pass 1 7300 objects audited
Pass 1 7400 objects audited
Pass 1 7500 objects audited
Pass 1 7600 objects audited
Pass 1 7700 objects audited
Pass 1 7800 objects audited
Pass 1 7900 objects audited
Pass 1 8000 objects audited
Pass 1 8100 objects audited
Pass 1 8200 objects audited
Pass 1 8300 objects audited
Pass 1 8400 objects audited
Pass 1 8500 objects audited
Pass 1 8600 objects audited
Pass 1 8700 objects audited
Pass 1 8800 objects audited
Pass 1 8900 objects audited
Pass 1 9000 objects audited
Pass 1 9100 objects audited
Pass 1 9200 objects audited
Pass 1 9300 objects audited
Pass 1 9400 objects audited
Pass 1 9500 objects audited
Pass 1 9600 objects audited
Pass 1 9700 objects audited
Pass 1 9800 objects audited
Pass 1 9900 objects audited
Pass 1 10000 objects audited
Pass 1 10100 objects audited
Pass 1 10200 objects audited
Pass 1 10300 objects audited
Pass 1 10400 objects audited
Pass 1 10500 objects audited
Pass 1 10600 objects audited
Pass 1 10700 objects audited
Pass 1 10800 objects audited
Pass 1 10900 objects audited
Pass 1 11000 objects audited
Pass 1 11100 objects audited
Pass 1 11200 objects audited
Pass 1 11300 objects audited
Pass 1 11400 objects audited
Pass 1 11500 objects audited
Pass 1 11600 objects audited
Pass 1 11700 objects audited
Pass 1 11800 objects audited
Pass 1 11900 objects audited
Pass 1 12000 objects audited
Pass 1 12100 objects audited
Pass 1 12200 objects audited
Pass 1 12300 objects audited
Pass 1 12400 objects audited
Pass 1 12500 objects audited
Pass 1 12600 objects audited
Pass 1 12700 objects audited
Pass 1 12800 objects audited
Pass 1 12900 objects audited
Pass 1 13000 objects audited
Pass 1 13100 objects audited
Pass 1 13200 objects audited
Pass 1 13300 objects audited
Pass 1 13400 objects audited
Pass 1 13500 objects audited
Pass 1 13600 objects audited
Pass 1 13700 objects audited
Pass 1 13800 objects audited
Pass 1 13900 objects audited
Pass 1 14000 objects audited
Pass 1 14100 objects audited
Pass 1 14200 objects audited
Pass 1 14300 objects audited
Pass 1 14400 objects audited
Pass 1 14500 objects audited
Pass 1 14600 objects audited
Pass 1 14700 objects audited
Pass 1 14800 objects audited
Pass 1 14900 objects audited
Pass 1 15000 objects audited
Auditing Entities Pass 2
Pass 2 100 objects audited
Pass 2 200 objects audited
Pass 2 300 objects audited
Pass 2 400 objects audited
Pass 2 500 objects audited
Pass 2 600 objects audited
Pass 2 700 objects audited
Pass 2 800 objects audited
Pass 2 900 objects audited
Pass 2 1000 objects audited
Pass 2 1100 objects audited
Pass 2 1200 objects audited
Pass 2 1300 objects audited
Pass 2 1400 objects audited
Pass 2 1500 objects audited
Pass 2 1600 objects audited
Pass 2 1700 objects audited
Pass 2 1800 objects audited
Pass 2 1900 objects audited
Pass 2 2000 objects audited
Pass 2 2100 objects audited
Pass 2 2200 objects audited
Pass 2 2300 objects audited
Pass 2 2400 objects audited
Pass 2 2500 objects audited
Pass 2 2600 objects audited
Pass 2 2700 objects audited
Pass 2 2800 objects audited
Pass 2 2900 objects audited
Pass 2 3000 objects audited
Pass 2 3100 objects audited
Pass 2 3200 objects audited
Pass 2 3300 objects audited
Pass 2 3400 objects audited
Pass 2 3500 objects audited
Pass 2 3600 objects audited
Pass 2 3700 objects audited
Pass 2 3800 objects audited
Pass 2 3900 objects audited
Pass 2 4000 objects audited
Pass 2 4100 objects audited
Pass 2 4200 objects audited
Pass 2 4300 objects audited
Pass 2 4400 objects audited
Pass 2 4500 objects audited
Pass 2 4600 objects audited
Pass 2 4700 objects audited
Pass 2 4800 objects audited
Pass 2 4900 objects audited
Pass 2 5000 objects audited
Pass 2 5100 objects audited
Pass 2 5200 objects audited
Pass 2 5300 objects audited
Pass 2 5400 objects audited
Pass 2 5500 objects audited
Pass 2 5600 objects audited
Pass 2 5700 objects audited
Pass 2 5800 objects audited
Pass 2 5900 objects audited
Pass 2 6000 objects audited
Pass 2 6100 objects audited
Pass 2 6200 objects audited
Pass 2 6300 objects audited
Pass 2 6400 objects audited
Pass 2 6500 objects audited
Pass 2 6600 objects audited
Pass 2 6700 objects audited
Pass 2 6800 objects audited
Pass 2 6900 objects audited
Pass 2 7000 objects audited
Pass 2 7100 objects audited
Pass 2 7200 objects audited
Pass 2 7300 objects audited
Pass 2 7400 objects audited
Pass 2 7500 objects audited
Pass 2 7600 objects audited
Pass 2 7700 objects audited
Pass 2 7800 objects audited
Pass 2 7900 objects audited
Pass 2 8000 objects audited
Pass 2 8100 objects audited
Pass 2 8200 objects audited
Pass 2 8300 objects audited
Pass 2 8400 objects audited
Pass 2 8500 objects audited
Pass 2 8600 objects audited
Pass 2 8700 objects audited
Pass 2 8800 objects audited
Pass 2 8900 objects audited
Pass 2 9000 objects audited
Pass 2 9100 objects audited
Pass 2 9200 objects audited
Pass 2 9300 objects audited
Pass 2 9400 objects audited
Pass 2 9500 objects audited
Pass 2 9600 objects audited
Pass 2 9700 objects audited
Pass 2 9800 objects audited
Pass 2 9900 objects audited
Pass 2 10000 objects audited
Pass 2 10100 objects audited
Pass 2 10200 objects audited
Pass 2 10300 objects audited
Pass 2 10400 objects audited
Pass 2 10500 objects audited
Pass 2 10600 objects audited
Pass 2 10700 objects audited
Pass 2 10800 objects audited
Pass 2 10900 objects audited
Pass 2 11000 objects audited
Pass 2 11100 objects audited
Pass 2 11200 objects audited
Pass 2 11300 objects audited
Pass 2 11400 objects audited
Pass 2 11500 objects audited
Pass 2 11600 objects audited
Pass 2 11700 objects audited
Pass 2 11800 objects audited
Pass 2 11900 objects audited
Pass 2 12000 objects audited
Pass 2 12100 objects audited
Pass 2 12200 objects audited
Pass 2 12300 objects audited
Pass 2 12400 objects audited
Pass 2 12500 objects audited
Pass 2 12600 objects audited
Pass 2 12700 objects audited
Pass 2 12800 objects audited
Pass 2 12900 objects audited
Pass 2 13000 objects audited
Pass 2 13100 objects audited
Pass 2 13200 objects audited
Pass 2 13300 objects audited
Pass 2 13400 objects audited
Pass 2 13500 objects audited
Pass 2 13600 objects audited
Pass 2 13700 objects audited
Pass 2 13800 objects audited
Pass 2 13900 objects audited
Pass 2 14000 objects audited
Pass 2 14100 objects audited
Pass 2 14200 objects audited
Pass 2 14300 objects audited
Pass 2 14400 objects audited
Pass 2 14500 objects audited
Pass 2 14600 objects audited
Pass 2 14700 objects audited
Pass 2 14800 objects audited
Pass 2 14900 objects audited
Pass 2 15000 objects audited
Auditing Blocks
Auditing AcDsRecords
Total errors found 0 fixed 0
Erased 0 objects
Drawing: ID-TB.dwg
Auditing Header
Auditing Tables
Stair Plan Display Props (Arrow DimStyle)
eNullObjectId Standard
Stair Plan Overlapping Display Props (Arrow DimStyle)
Auditing Blocks
Total errors found 3 fixed 3
Erased 0 objects
Drawing: x4132_00 Cellar - FP.dwg
Auditing Header
Auditing Tables
AcDbSortentsTable(4D7E)
Error for Entry (175A0) eInvalidInput was Removed.
Auditing Blocks
Total errors found 1 fixed 1
Erased 0 objects
Drawing: LJ-x4132_BP_00_Cellar.dwg
Path: C:\Users\dsaadallah\Desktop\ID-100 KT\Consultants
Auditing Header
Auditing Tables
Invalid anonymous block "*U714" found in Block symbol table.
Changed to normal block "AUDIT_I_160713153512-0".
Invalid anonymous block "*U695" found in Block symbol table.
Changed to normal block "AUDIT_I_160713153512-1".
Invalid anonymous block "*U666" found in Block symbol table.
Changed to normal block "AUDIT_I_160713153512-2".
Invalid anonymous block "*U668" found in Block symbol table.
Changed to normal block "AUDIT_I_160713153512-3".
Invalid anonymous block "*U699" found in Block symbol table.
Changed to normal block "AUDIT_I_160713153512-4".
Invalid anonymous block "*U7110" found in Block symbol table.
Changed to normal block "AUDIT_I_160713153512-5".
Auditing Blocks
Total errors found 9 fixed 9
Erased 0 objects
Drawing: N1604_KINGS_TOWN_CELLAR.dwg
Path:
The drawing file could not be found
