01:56 PM
I have AutoCAD 2016 (full version) and am setting up AutoCAD LT 2016 (light version) for a coworker. I noticed when navigating to the preferred file paths in the Options window, "Sheet Set Template File Location" and "Default Template for Sheet Creation and Page Setup Overrides" aren't showing up under the "Template Settings" tree. Is this a full version privilege only, or is there a way to get this to show up? I know I can edit the properties of each individual sheet set, but I want to revert to the same file every time. See attached .jpg if my description doesn't make sense. Thanks for the feedback!
