AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Using pyautocad on AutoCAD LT
1 REPLY 1
2878 Views, 1 Reply
I am currently trying to develop automated drawing tools on AutoCAD LT using python. It seems like pyautocad is only available for AutoCAD and not for for the LT version. Is there any way I can use pytautocad on LT ? If not, what programming language is available for AutoCAD LT ?
Tags (2)
Labels (1)
1 REPLY 1
steven-g
None, unless you want to count 'diesel' as a programming language, (not many people do. There are no API's available in LT that is one of the reasons it is so much more affordable. If you want any form of automation in LT then you would need to look at using an external program to create scripts, but there can be no interaction between a script and a .dwg file except for the script file telling LT to draw objects basically.
Seriously if you want automation then you have to have the full version.
Forma Design Contest
Technology Administrators
