Hello everyone!
I hope you can help me with the following question as I have not been able to find an answer for it in the forums.
Suppose I have 4 layouts. and I want to automatically list the pages for example
page 2 of 3.
I already saw that with "CTAB" I can place the number "2" renaming the layout, but the second number that will be the total number of pages that I have, I have not been able to place it.
I know that through an lsp they can do it, the problem is that I have LT, and this version does not accept lsp.
I have seen some fields called sheetnumber but really I have not found if it works for what I need.
Thanks for helping.
I personally don't use them but I believe the 'sheet set manager' is what you would need to look at.
Hi @Anonymous,
In full AutoCAD there is a LISP variable for Total sheets count under the Other field category, however, LISP is not supported in LT. Instead, a text block referenced from a field can be used to show the sheet count.
Note, that the text block would need to be manually if the sheet count changes.
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
