User defined Hatch patterns.
david_2
david_2
I have moved from LT10 for WIN 7 to LT23 for WIN 11.  I created several user defined hatch patterns and saved them in the user section of a file named 'acadltiso.pat'.  I have this file saved in a separate directory on my new computer and I want to add these definitions to LT23, but I cannot find where the hatch patterns are stored in the new installation. I have run a search in File Manager, but it cannot find anything. Can anyone please help with a TREE string so I can get them working again.  Also, would this old file work in LT23?  It has the original definitions listed.  Thank you.
Accepted solutions (4)
paullimapa
All support files including acadltiso.pat should be here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-acadiso-pat-...
Paul Li
IT Specialist
@The Office
WeTanks
it's here.
Older files can be used.
English is my second language.
Please don't worry if I make any English mistakes.
英語は母国語ではない
英語のミスをしても気にしないでください。
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
david_2
Mine looks a bit different to yours, see here:
It does not have the 'Working support file search path'.  I have not found the hatch pattern files yet,still looking,but thanks for your reply.
david_2
Thank you, I have found the PAT files in the directory your reply suggested.
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
