I have moved from LT10 for WIN 7 to LT23 for WIN 11. I created several user defined hatch patterns and saved them in the user section of a file named 'acadltiso.pat'. I have this file saved in a separate directory on my new computer and I want to add these definitions to LT23, but I cannot find where the hatch patterns are stored in the new installation. I have run a search in File Manager, but it cannot find anything. Can anyone please help with a TREE string so I can get them working again. Also, would this old file work in LT23? It has the original definitions listed. Thank you.
Solved by paullimapa. Go to Solution.
Solved by david_2. Go to Solution.
Solved by WeTanks. Go to Solution.
All support files including acadltiso.pat should be here:
it's here.
Older files can be used.
English is my second language.
Please don't worry if I make any English mistakes.
英語は母国語ではない
英語のミスをしても気にしないでください。
Mine looks a bit different to yours, see here:
It does not have the 'Working support file search path'. I have not found the hatch pattern files yet,still looking,but thanks for your reply.
Thank you, I have found the PAT files in the directory your reply suggested.
Glad to have helped…cheers!!!
