AutoCAD LT Forum
User defined Hatch patterns.
5 REPLIES 5
david_2
586 Views, 5 Replies
I have moved from LT10 for WIN 7 to LT23 for WIN 11.  I created several user defined hatch patterns and saved them in the user section of a file named 'acadltiso.pat'.  I have this file saved in a separate directory on my new computer and I want to add these definitions to LT23, but I cannot find where the hatch patterns are stored in the new installation. I have run a search in File Manager, but it cannot find anything. Can anyone please help with a TREE string so I can get them working again.  Also, would this old file work in LT23?  It has the original definitions listed.  Thank you.
5 REPLIES 5
paullimapa
in reply to: david_2
All support files including acadltiso.pat should be here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-acadiso-pat-...
Paul Li
IT Specialist
@The Office
WeTanks
it's here.
Older files can be used.
English is my second language.
Please don't worry if I make any English mistakes.
英語は母国語ではない
英語のミスをしても気にしないでください。
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
david_2
in reply to: WeTanks
Mine looks a bit different to yours, see here:
It does not have the 'Working support file search path'.  I have not found the hatch pattern files yet,still looking,but thanks for your reply.
david_2
in reply to: paullimapa
Thank you, I have found the PAT files in the directory your reply suggested.
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
Technology Administrators
