Update 2018.0.2 is available for AutoCAD and AutoCAD LT and the AutoCAD based vertical products. If you have the 2018 version of those products, you can get it from the Autodesk desktop app or by finding it in your Autodesk Account.
AutoCAD only
Note: The 2018.0.2 update fixes an issue that would otherwise have caused the product to expire on June 1, 2017 with a pre-release product error message. Be sure to install this update before that time to avoid product expiration. If the About dialog shows product version number as 0.61.0.0, this update should be applied. Once the update is installed, the version number in the About dialog will show 0.72.0.0
Affected products include:
Please see this AKN article for additional details.
Solved by Emmsleys. Go to Solution.
Check your Autodesk Account Management page for a complete list:
Access update via the Community
You can also access you it from right here in the Community by clicking Account Settings at the top right of this window.
Once it takes you to your Settings page click on Management.
Access the update through Autodesk Account:
Another easy way to get to your Account Management is to sign on in the Autodesk home page.
Once you are in your Account Management page, check out the Product Updates section or, look for the Updates & Add-ons listed under your application.
Thanks for your post.
However, some users will not be able to do the update due to various reasons and will find their software locked on June 1st.
What is the procedure for users to get AutoCAD LT running again when update 2 has not been implemented?
At the moment the only fix that is available is to apply the update. In order to access and run AutoCAD LT 2018. If they have other AutoCAD LT applications running like AutoCAD LT 2017,2016,2015 I would suggest trying to run those in the interim. Until you can apply the update.
Let me know if you have any other questions.
Hi Sarah, I have just relicensed with AutoCAD LT 2018 and downloaded it onto my desktop and laptop. It is successfully activated on the desktop, but won't do so on the laptop. I have been using LT since 2015 on both machines without a problem, but now it seems it won't let me do this. Can you advise what I might do? I need the laptop for client meetings, or when I am traveling and use the desktop, with its bigger screen, for most of my work.
I have attached an image of what comes up on my laptop screen.
Thanks.
Andrew
