AutoCAD LT 2016. I'm getting the message every time I start the computer:
Unable to run Application Manager. It appears Autodesk Application Manager service is not available. Please close all other instances and retry.
What to do ??
Solved by pendean. Go to Solution.
I'm still having this error message when I log in into Windows 7. I don't have the appropriate rights to turn off or on the User Account Control like a lot of Autodesk users in the world. So I'm asking myself, what is this for terrible solution? Please come with a good, permanent solution.
Solution:To work around this issue, turn off the UAC control in windows.Alternatively, you can run the Application Manager with Administrator privileges.
- Right click the Application Manager > Properties > Compatibility tab and turn on the checkbox “Run this program as an administrator.”
Thanks pendean, I will contact our system administrator.
It's still a WORK-AROUND as stated on this page, a workaround means there's no structural solution... Why is this a problem suddenly?
Please help me I don't know what to do after enter in that link!
Solution:
This is resolved in the latest release of Autodesk Home Version 6.0.33.5
But after that What am I supposed to do??
does anyboday else know what this informations is about?
Autodesk® Desktop App 6.0.33.5 seems to be not available anywhere.
My A 360 Desktop app is version 6.2.10.1700 though. Are you referring to this?
Regards.
Marco
