Troubleshoot xref screening
chick.biker
Message 1 of 19
chick.biker
My drawing file is printing to pdf with the xref screened.  I have selected layers I would like to screen, but the rest should print black.  I did some research and reset the XDWGFADECTL system variable, I've checked my plot table settings, I can't find a source of the problem.  See attached screenshots.  Flummoxed.
Chick.biker
Replies (18)
Message 2 of 19
paullimapa
I don't see any XREFs nor XREF Layers listed:
Paul Li
IT Specialist
@The Office
Message 3 of 19
pendean
Community Legend
Community Legend
PLOT TRANSPARENCY is turned on/box checked by chance?
All the "fade" setting in AutoCAD are for display-on-screen purposes only. Nothing has changed about them through the 2024 versions yet. So it's likely something else. I too see no XREF in your layer list. Did you bind it and now it is a block?
Start testing (I am assuming CTB, not STB):
1) PLOT using only NONE for a plot style table: same issue occur?
2) PLOT with monochrome plot style table: same issue occur?
Message 4 of 19
chick.biker
I uploaded the wrong screenshot for the layer list.  The correct one is here. Apologies.
Chick.biker
Message 5 of 19
chick.biker
Apologies.  Hard to see screenshots when you select them to upload.  See correct one I just uploaded.
Chick.biker
Message 6 of 19
chick.biker
Will try your suggestions. I uploaded the correct screenshot of layer table this am, apologies.
Chick.biker
Message 7 of 19
paullimapa
Now share the pdf that shows the screened layers. Also do a screen capture of your Plot window used to create the pdf and share that here as well
Paul Li
IT Specialist
@The Office
Message 8 of 19
chick.biker
Oops, just realized I don't understand what a monochrome plot style table is - please explain.
Chick.biker
Message 9 of 19
pendean
Community Legend
Community Legend
See screenshot
Message 10 of 19
chick.biker
Here is the plot window and pdf.
Chick.biker
Message 11 of 19
chick.biker
Monochrome test. Seems normal.
Chick.biker
Message 12 of 19
paullimapa
Pdf looks good. What’s the problem?
Paul Li
IT Specialist
@The Office
Message 13 of 19
chick.biker
None as page setup.  Sheesh.  How could the page setup introduce screening?
Chick.biker
Message 14 of 19
chick.biker
Here's the attachment.
Chick.biker
Message 15 of 19
chick.biker
I need to screen select objects, this doesn't accomplish that.  When I try, all the plants in the existing conditions get screened.
Chick.biker
Message 16 of 19
paullimapa
@chick.biker wrote:"I need to screen select objects"
What does this mean?
I'm not sure what you're trying to do.
@chick.biker wrote:  "When I try, all the plants in the existing conditions get screened"
Are you saying you only want certain plants to be screened and not others?
Are those certain plants placed in a different layer than the other plants so that layers can be treated differently?
Could you share your dwg?
Can you mark up which plants are the ones you want to be screened?
Paul Li
IT Specialist
@The Office
Message 17 of 19
pendean
Community Legend
Community Legend
You may need to edit your custom CTB file to correct the screening: hard to tell without your DWG file and custom CTB file.
Your choice of the Microsoft PDF driver is not a choice I would use: any reason one of the 5+ PDF drivers bundled with AutoCAD/LT are not working for you?
Message 18 of 19
chick.biker
I need to screen the plants in the xref, not in the current file.  Makes a pretty clear distinction between categories of plants.
Chick.biker
Message 19 of 19
paullimapa
try this:
Paul Li
IT Specialist
@The Office
