I have the same problem as above, but TEXTSCR doesn't bring the window to the front. It is sitting in my task bar, but when I click on it, it won't pop up. The only way to view it is to minimise CAD, hover over the taskbar until the preview window pops up and click on the text window. It doesn't do this all the time, so wondering what is triggering it. A CAD restart fixes it temporarily, but wondering if there's a permanent fix.
There is no longer a pop-up as in the older versions where you responded.
Docking the commandline, to match the old versions, may be what you are looking for? Also explore this from Autodesk http://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Aut...
and this http://autocadtips1.com/2015/01/15/number-of-lines-of-command-history-on-the-command-line/
So this window that pops up (but stays behind the drawing window) when I press F2 doesn't exist?
