I recently upgraded to AutoCAD LT 2016. After searching through the HELP menu, I found that when using Ortho Mode the Polar Tracking is automatically turned off (and visa-versa). I need to use both commands simultaneously. Is there any way to override the Polar Tracking settings, so that it doesn’t automatically turn off when Ortho Mode is active? For the past 12 years of my career, I have always used Ortho Mode and Polar Tracking at the same time, and haven’t found an efficient way to draft in certain situations without these commands working together. Help!??!!??
Solved by pendean. Go to Solution.
Welcome to the Forums
No they are two mutually exclusive settings you cannot have both on at the same time.
HOWEVER you can simulate Ortho mode in Polar mode by changing the angle in Polar mode to an angle which fits excatly into 90 degrees eg 7.5, 15, 30, 45, 90
Howard Walker
So I tried the Object Snap Tracking, and yes - that is what I've always used. Thank you so much!!!! I now have my setting back. I can use Ortho Mode and Object Snap Tracking simultaneously - which are the two commands that I've always previous used. Thank you for the clarification!
