Standard scale list issue
abi.saunders
Message 1 of 27
abi.saunders
I have a problem on a few of my .dwg files but not all of them - so I know it must be a setting somewhere.  When I try to change a viewport scale via the pull down menu (properties, misc, standard scales) I can see the available scales but the curser jumps over the options and doesn't allow me to select the scale I want. I can still change the scale via the 'custom scale' dialogue box, so I have a workaround- but such a simple problem is driving me crazy!  I can't find an answer on any forum topics so far. Please help....
Replies (26)
Message 2 of 27
h_s_walker
What version of LT are you using?
Is it updated to the latest version?
Download Autodesk Screencast | Search | Autodesk Knowledge Network
Download Screencast from the above link and then record what's happening and post the video here so we can see what it's doing as well
Howard Walker
Left Handed and Proud
Message 3 of 27
abi.saunders
I'm using Lt 2022.
Message 4 of 27
pendean
Community Legend
Community Legend
Works fine here. If it only happens in "some files", maybe you need to fix those files with RECOVER command. Do you know how to use that command?
ALSO... Have you installed the LT2022.1.2 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards <<<< THIS IS AN IMPORTANT STEP
Message 5 of 27
abi.saunders
I have just updated to the latest version and it still happens unfortunately
Message 6 of 27
pendean
Community Legend
Community Legend
That's unfortunate.
Message 7 of 27
abi.saunders
I have done and uploaded my 1st ever screencast- but no idea where it went! I'm off to a meeting now....hoping the 'fixer fairies' will have a solution when I return 🤞
Message 8 of 27
h_s_walker
Here's a link to your screencast so maybe @pendean can have a look and see what's happening
Scale list edit problem | AutoCAD LT 2022 | Autodesk Knowledge Network
As for me the only thing I can suggest is delete that viewport and then make a new one.
Howard Walker
Message 9 of 27
pendean
Community Legend
Community Legend
I am going to have to agree with @h_s_walker suggested fix.
Message 10 of 27
steven-g
Odd behaviour indeed, can you post a copy of the file to see if we get the same results. Or maybe can find what the problem is?
Message 11 of 27
abi.saunders
FYI the problem was not solved. I've just been too busy to post on the forum.
I can continue working by manually typing in the scale rather than using the pull down menu. I have also opened an old drawing from 2 years ago this morning and that too has the same issue.
Message 12 of 27
cadffm
As mentioned before: Upload one sample(.dwg) an tell us the scale name
and create screencast - also mentioned before.
If  I have to guess, i think inside your file you have one or more other scales with the same scale-defintion.
(not the name is the same, but the definition behind).
Sebastian
Message 13 of 27
abi.saunders
I made a screencast and thought it uploaded....a bit of an amateur on that so no I've cut and pasted this!
You might be interested in this Screencast:
This is a blank template drawing I created myself. The viewport I first try to change the scale is working fine at this point but there are some odd scales that I want to remove. The second viewport I try to change has the problem I am trying to decribe- at this point I have used the scale list edit function to remove unwanted scales. You can see I cannot select the scale I want even though the sale is there. Sometimes and for no appearent reason the veiwport works as normal- but the 1:200 scale appears on the top of the scale list with others I have not added/ seen before.
https://autode.sk/3tWwzD0
Message 14 of 27
cadffm
Would you please test it with your uploaded file again?
Because if I open your "test.dwg", the upper right viewport IS LOCKED
and your sample in screencast it isn't - it isn't the same file and the viewport isn't locked.
Make no sense to compare different files.
Note: With our uploaded file, I don't have problems with my
AutoCAD 2022.1.2
and also not with my Acad LT 2022(.0.0)
What is your product version? Check it, command: ABOUT
What is your OS ?
Sebastian
Message 15 of 27
abi.saunders
You can just unlock the vp- the scale problem will be when changing an unlocked VP to a predetermined scale in the pull down menu
Message 16 of 27
cadffm
>>"You can just unlock"
lol - That is not the point, the point is that we compare the same filestate/data!
Of course, I've done this before and I've already told you:
I have no problems with the file!
Neither in ACAD LT 2022.0.0 nor in AutoCAD 2022.1.2
1. I asked you if you could please check the problem again in your uploaded file
2. I asked for your product version, command: ABOUT
As I said: I couldn't understand the problem, it works for me with your TEST.dwg file without any problems.
Sebastian
Message 17 of 27
abi.saunders
Perhaps you can read your response and appreciate how rude it comes across.
I'll leave now and hope I don't need to ask for help again.
Message 18 of 27
cadffm
If you can not focus to your technical issue - IO am sorry, but this is you problem.
Try to read the technical information and ignore whatever scratching your feelings.
(English isn't my native language, I can only apologize and state that this is not intentional.)
I have nothing to do with your bruised feelings, I don't have time for that.
If you need help with AutoCAD, I'm happy to help. - Post your ProductVersion, command: ABOUT
and please: Try it again in the file you shared with us.
Sebastian
Message 19 of 27
abi.saunders
I am sorry too- I need to work right now. I have a workaround for this and hoped it was a quick fix, clearly it is not.  Work comes first so apologies I can't just quickly re do what I had done wrong before. Product Version as below- I will try to look at resending the .dwg file when I can.
PS Language is one thing, but no need for all the exclamation marks-  IT'S LIKE WRITING WITH CAPS LOCK ON. I have not taken offense, or have bruised feelings but rather surprised that assistance is offered in such a curt manner.
Message 20 of 27
cadffm
Note: We all have to work, we all are users like you and no one get money from you (or any other spender),
you are in an public user forum.
Okay, as I said:
Please try it your uploaded TEST.dwg - if you have the same issue in this file - I am sorry, but I can not reproduce the isse on my side.
If you can't reproduce the issue in this file, please share another one.
Productversion: Thank you for sharing
>>"LIKE WRITING WITH CAPS LOCK ON"
I wrote in caps lock the IMPORTANT parts like differences or COMMAND names,
that's absolutely usual and a good syntax. Also in official Books and tutorials.
Sebastian
