When I snap (any type of snap) it will show the snap icon as it understood where I want to snap but it will snap toa diferent point farther away from where I indicated it to snap. This is a big problem, creating inacuracies that sometimes are visible (when really zoomed in) and some times impreceptible.
Any solutions? Cant find anything in Forum that works for me.
Thank you!
C.
Can you verify that this is not just a display issue by checking x,y,z point locations?
I'm thinking that unless the input is incorrect that the snaps are working correctly and the display is not as expected.
@clarisa24 wrote:
I checked point locations, everything looks good. Everything is in elevation 0 - if that is what you refer to.
Yeah, there are two other coordinates that need to be checked, though. Since you say everything "looks" good, it sounds like you have some doubt. Share a file generated with these discrepancies so we can verify what the problem is and point you to an appropriate solution.
@clarisa24 wrote:
Attached is one of the files with this problem (although if happens with all)
That's fine but there isn't a file attached.
Where are the problem areas?
I see a couple places that could use some cleaning up but not really sure if they are related to your issue.
Snaping is the problem. I know the drawing is not clean, however snaps are snaping inaccuretley. Any snap and for any comand, draw, dimension....
Here is a link to the screencast. You can see that it starts snaping correctly from end point to end points, and then all of the sudden it wont snap to end point anymore. Also al of the sudden it looks as though I did not snap the first line to be copied correctly. However, I was able to snap accuratley the first few lines.... Its very strange.
I hope you can see in the video.
Thanks!
