AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
merge layers command freezes up autocad
2 REPLIES 2
951 Views, 2 Replies
Autocad 2020. When I try to merge layers the program completely freezes up and I have to restart my computer. This was not such a problem in autocad 2018 LT. It only happend every so often. The 2020 is generally all around slower than the 2018 but the merge layer command is the only one that is really bad.
2 REPLIES 2
rkmcswain
Does this happen in every drawing, even an empty new one where you create a couple of layers......or just one particular drawing?
R.K. McSwain     | CADpanacea | on twitter
pendean
>>>...It only happend every so often...<<<
Find out what is unique at that moment when it fails: it will probably fail at the same point in 2018 too. There is no universal fix for "sometimes", that simply means you might have something else going on.
BTW did you install the 2020.1 update yet? Came out late last week, you need to install it either way.
Technology Administrators
