AutoCAD LT Forum
Sequential Autosave
2 REPLIES 2
368 Views, 2 Replies
Sequential Autosave
Thanks in advance.
So is there a way to set the autosave to work sequentially not consecutively?
I have read numerous posts and no this is not to do with bad file saving methodology.
This is primarily to help me ensure time sheets are accurate.
Where I used to work we used a peice of software called Caddie not Autocad and it autosaved every drawing every 15mins back to a single folder, yes this eventually took up a load of space.
This was particularly usefull if I was jumping between multiple drawings I could ensure that I only allocated time back to the client whose drawing size had changed in the 15 mins, if I doing some concept work than doing a save as every 30seconds would be impractical or had a client claim that the hours were unreasonable i could print a 15min by 15min set of drawings to show works done.
Thanks again.
John
2 REPLIES 2
pendean
There is no such feature in AutoCAD.
in reply to: pendean
Shame but not unexpected.
Many Thanks for taking the time.
Forma Design Contest
Technology Administrators
