AutoCAD LT Forum
selecting a (duplicate) line under another line?
14 REPLIES 14
Message 1 of 15
89250 Views, 14 Replies
Is there an easy way to do this, tabbing doesn't do it.  I've always had trouble selecting a line buried under anothe one.
14 REPLIES 14
Message 2 of 15
steven-g
   With your cursor positioned over the line (lines) press and hold the shift key down and then repeatedly press on the space bar to tab through the objects below the cursor. Once the one you want is highlighted click with the mouse to select it.
Regards
 Steve
Message 3 of 15
in reply to: steven-g
Thank you Steve, that will be a good help.  Joe
Message 4 of 15
Thanks steve!!!!!
Message 5 of 15
heinsite
There is another option if you're using LT 2011 or 2012: Selection Cycling.
Set the system variable SELECTIONCYCLING=2 to turn it on or activate it by clicking its icon on the Status bar at the bottom of the screen.  When you move your cursor over an object that has others beneath it you'll see two small boxes.  Select the object and a Selection box will come onscreen showing you what else is there.  Move your cursor over them and left click to select the one you want.
Having selection cycling on all the time can slow down performance... so I leave it off most of the time.
Dave.
Dave Hein, P.E.
Message 6 of 15
Use draw order (dw)
Message 7 of 15
My cursor does not give me the double box option when placed on line where duplicate lines are drawn.  Where can this be set?
Message 8 of 15
pendean
double-box option?
What is SELECTIONCYCLING set to? Look it up in HELP and change it to see if that helps.
Message 9 of 15
in reply to: pendean
In autocad LT 2008 ,how can i select object that is below other object?
none of theese ideas work..... 😞
Message 10 of 15
cadffm
Select both (Cross-Selection) and remove the upper object.
Crosswindow-selection
type-in R or REMOVE [or just press SHIFT while] click the upper object,
voila.
Sebastian
Message 11 of 15
gotphish001
You can also turn on SELECTIONCYCLING. When you click on a spot that has more than one thing, it gives you a pop up that shows each object and the color of the layer each is on. You then click on which one you want. The top object in the list is the object on top in the drawing and they go down from there corresponding. If you don't click on anything in the pop up and just continue what you are doing it automatically selects the top object the same as it would with selectioncycling turned off. You can add a button to turn this off and on to the bottom toolbar. That way you can turn it on if you have a really cluttered drawing with lots of overlap.
Nick DiPietro
Cad Manager/Monkey
Message 12 of 15
cadffm
in reply to: gotphish001
Not in 2008, or?
Sebastian
Message 13 of 15
any other aimple method?
by using some mouse setting .
Message 14 of 15
Thank You Steve. You saved my week.
Message 15 of 15
in reply to: heinsite
Thanks! that was helpful
Technology Administrators
