select object under hidden line
I have a hidden (dashed) line on top of a solid line. I want to move or copy the solid line.  I use to be able to simply select the solid line between the dashes on the hidden line.  Now the hidden line acts like a solid line and I cannot select the line (or other object) below the hidden line. Can that be fixed? I am sure there is a select/tab/deselect move (or something) that may work if the draw order remains intact - however, I want to simply select the line below the hidden line without making 3 keyboard/mouse strokes.
Thank you
Jeff O
cadffm
Charles_Shade
Thanks.
Another variable to know...
