AutoCAD LT Forum
scale imported pdf
4 REPLIES 4
carmoore
1275 Views, 4 Replies
scale imported pdf
After I import a PDF and draw the perimeter of the building using a polyline, I want to increase the size of the drawing/polyline to the actual size of the building.  In other words, if I know one of the perimeter dimensions is 50', how do i scale the drawing to have that line actually be 50' in model space.  Cant figure out how to do that. Using LT 2017.
4 REPLIES 4
rkmcswain
in reply to: carmoore
john.vellek
Hi carmoore,
This is actually a pretty easy thing to do. Here is a link that describes the SCALE command.
The option you want to use is REFERENCE.
I don't have a PDF handy but it is a similar concept to what I include in my screencast. Please let me know if this helps or if you need additional assistance.
The only image file I had was my own picture so please forgive me - I am not really that vain 🙂
You can see in the screencast that I select the image file, a base point on the line that I want to match length of, then the length of the image and then the desired length.
So, in a PDF you just need to select the two points that will correspond to the known length in your drawing.
If you want to attach your files I can show you how to scale them  with a video.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi carmoore
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit. If you would like to attach the PDF and the drawing I can do another screencast with your files to show you how you can resolve the scale issue.
John Vellek
carmoore
in reply to: john.vellek
I found a you tube video abou **** that solved the issue. It explains the
"reference" fooled by "points" portion of the process.
Submitted,
Carl Moore
Modern Roof Consulting, Inc
16D Municipal Drive
Arnold, MO 63010
carl@modernroofconsulting.com
Office: 636.349.8056
Cell: 314.973.6439
Technology Administrators
