After I import a PDF and draw the perimeter of the building using a polyline, I want to increase the size of the drawing/polyline to the actual size of the building. In other words, if I know one of the perimeter dimensions is 50', how do i scale the drawing to have that line actually be 50' in model space. Cant figure out how to do that. Using LT 2017.
Solved by carmoore. Go to Solution.
Solved by john.vellek. Go to Solution.
Hi carmoore,
This is actually a pretty easy thing to do. Here is a link that describes the SCALE command.
The option you want to use is REFERENCE.
I don't have a PDF handy but it is a similar concept to what I include in my screencast. Please let me know if this helps or if you need additional assistance.
The only image file I had was my own picture so please forgive me - I am not really that vain 🙂
You can see in the screencast that I select the image file, a base point on the line that I want to match length of, then the length of the image and then the desired length.
So, in a PDF you just need to select the two points that will correspond to the known length in your drawing.
If you want to attach your files I can show you how to scale them with a video.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Hi carmoore
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit. If you would like to attach the PDF and the drawing I can do another screencast with your files to show you how you can resolve the scale issue.
