Save as not working
Save as not working
Message 1 of 12
Save as not working
2019 LT....I cannot "save as". The screen locks up every time and I have to hit "esc" to continue working. I can "save" but not "save as".
Help!!
Replies (11)
Message 2 of 12
user181
Hi @Anonymous,  Is it just the one drawing saveas doesn't work?  You can use the WBLOCK command and select all objects and that will create a new drawing.
Message 3 of 12
cadffm
Message 4 of 12
No, all drawings I have this issue with.
Message 5 of 12
user181
@cadffm,  I think you may have linked to the wrong thread
Message 6 of 12
Patchy
Lock up or you cannot see the dialog box ?
If you can't see the dialog box, it could be off the screen.
Message 7 of 12
Locked up. I thing happens. I hit ESC to continue working but cannot save as.
Message 8 of 12
Patchy
Restore your autocad to default if it keep locking up.
Message 9 of 12
cadffm
@user181
Thank you, but no - it was the right link.
I thought the SaveAs dialog would be out of display, therefore the link to:
..start XY command, and:
The press [ALT]+[SPACE] then [M], now hit an arrow key like left or right arrow (not from the numpad), NOW the dialog hangs on the cursor
and you can move them with your mouse back to the visible screen (move mouse, without hit any key).
Sebastian
Message 10 of 12
user181
@cadffm  I see that now, I guess I should have read the whole thing.
Message 11 of 12
pendean
Community Legend
Community Legend
Could it be your pop-up is simply off-screen? https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Dialog...
Or are you seeing a long file location string at the commandline?
Message 12 of 12
jayhar
Hello friend
Reset Settings To Default AutoCAD LT
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
