AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Ribbon display
4 REPLIES 4
1359 Views, 4 Replies
Ribbon display
Notmally I can see a whole lot of command icons below the comands line (i.e. below File, Edit, View, .....Help). For some mysterious reason (perhaps I inadvertently pressed something) it has all gone and I can not see in help how to turn all the ribbon comand icons back on again.
4 REPLIES 4
cadffm
in reply to: cadffm
Hi AutoCad support:
Thanks, the ribbon command helps in part. I used to have all the icons in
locked display mode, as opposed to Autohide. At least I can now get all the
command icons (which autohide), so thank you.
cadffm
AutoCAD support?
You are in a public User Forum (hosted from AutoDESK, but a User Forum),
so we are all 'just users like you - some with more and some with less knowledge.
Read your AutoDESK LT - Help [F1]
about how to controle display ribbon <clickmenow>
Sebastian
pendean
Technology Administrators
